Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
DX58OG freezes when loaded with 24GB
Community Manager
I have been the happy owner of a DX58OG motherboard that has been running with 16GB CORSAIR Dominator CMX8GX3M2A1333C9memoy (4 x 4GB in dual channel mode) for over a year. It has the latest BIOS from Intel website and has a i7 950 (DO stepping) CPU running at stock speed. I have been running at stock voltages and 1066 stock speed fully stable.
Recently I needed to upgrade to 24GB so I ordered high quality memory from CORSAIR Vengeance CMZ24GX3M6A1600C9 which are siz sticks of 4GB memory that are matched. I can run 4 sticks of just fine but when I install all six it will pass memtest86 but when I run prime95 set to use 18GB of memory after 10 mintes it would freeze. My max system temps durring the full load tests are CPU 65C, IOH 52C and VREG 48C.
I worked with CORSAIR to set VRAM and DRAM/QPI to various settings but no matter what voltage and combination I would get freezes within a few minutes under heavy load. I also tried increasing CPU core voltage and that did nothing to help. I then purchased 6 pieces of Samsung M378B5273DH0-CH9 memory that is appoved by Intel on this board and it still freezes ( I sent this memory back).
I have searched this intel forum and have found at least six other posts with similar problems using 24GB memory with this motherboard. Only one person had a resolution and that was to have his mother board RMA'ed. I am thinking that either the DG58OG is faulty and needs replacing or the motherboard is not truely a stable 24GB motherboard even though it is stated to support 24GB. Does intel maybe have an other BIOS that would solve this problem?
Please help.
SYSTEM SPECS:
--------[ Summary ]-----------------------------------------------------------------------------------------------------
Computer:
Computer Type ACPI x64-based PC
Operating System Microsoft Windows 7 Ultimate
OS Service Pack Service Pack 1
Internet Explorer 9.0.8112.16421
DirectX DirectX 11.0
Date / Time 2013-02-05 / 11:38
Motherboard:
CPU Type QuadCore Intel Core i7 950, 3200 MHz (24 x 133) DO stepping
Motherboard Name DX58OG
BIOS Type Intel (01/29/12)
Motherboard Chipset Intel Tylersburg X58, Intel Nehalem
System Memory 24565 MB (DDR3-1333 DDR3 SDRAM)
DIMM1: Corsair CMZ24GX3M6A1600C9 4 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (7-7-7-19 @ 518 MHz) (6-6-6-16 @ 444 MHz)
DIMM2: Corsair CMZ24GX3M6A1600C9 4 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (7-7-7-19 @ 518 MHz) (6-6-6-16 @ 444 MHz)
DIMM3: Corsair CMZ24GX3M6A1600C9 4 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (7-7-7-19 @ 518 MHz) (6-6-6-16 @ 444 MHz)
DIMM4: Corsair CMZ24GX3M6A1600C9 4 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (7-7-7-19 @ 518 MHz) (6-6-6-16 @ 444 MHz)
DIMM5: Corsair CMZ24GX3M6A1600C9 4 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (7-7-7-19 @ 518 MHz) (6-6-6-16 @ 444 MHz)
DIMM6: Corsair CMZ24GX3M6A1600C9 4 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (7-7-7-19 @ 518 MHz) (6-6-6-16 @ 444 MHz)
Display:
Video Adapter NVIDIA GeForce GTX 560 Ti (1024 MB)
Monitor Dell 2408WFP (Digital) [24" LCD] (G283H8721JAS)
Multimedia:
Audio Adapter Realtek ALC892 @ Intel 82801JB ICH10 - High Definition Audio Controller
Storage:
IDE Controller Standard Dual Channel PCI IDE Controller
Storage Controller Intel(R) Desktop/Workstation/Server Express Chipset SATA RAID Controller
Storage Controller Marvell 91xx SATA 6G Controller
Disk Drive Corsair CSSD-F120GB2 SCSI Disk Device (111 GB)
Disk Drive Volume0 (1397 GB, IDE)
Optical Drive DTSOFT Virtual CdRom Device
Optical Drive HL-DT-ST DVDRAM GH22NS50
SMART Hard Disks Status OK
Partitions:
C: (NTFS) 111.8 GB (23.9 GB free)
D: (NTFS) 1397.2 GB (1181.2 GB free)
Total Size 1509.0 GB (1205.1 GB free)
Input:
Keyboard HID Keyboard Device
Keyboard Logitech HID-compliant Unifying keyboard
Mouse HID-compliant mouse
Mouse Logitech HID-compliant Unifying Mouse
Network:
Network Adapter Intel(R) 82567LF-2 Gigabit Network Connection (192.168.0.191)
Peripherals:
Printer Adobe PDF
Printer Fax - HP Officejet 6500 E710n-z (Network)
Printer Fax
Printer HP Officejet 6500 E710n-z (Network)
Printer Microsoft XPS Document Writer
Printer Send To OneNote 2010
FireWire Controller AT&T/Lucent IEEE1394 FireWire Controller (PHY: Agere LFW3226/3227)
USB1 Controller Intel 82801JB ICH10 - USB Universal Host Controller
USB1 Controller NEC uPD720200 USB 3.0 Host Controller
USB2 Controller Intel 82801JB ICH10 - USB2 Enhanced Host Controller
USB Device Logitech Unifying USB receiver
USB Device USB Composite Device
USB Device USB Input Device (Logitech Download Assistant)
DMI:
DMI BIOS Vendor Intel Corp.
DMI BIOS Version SOX5820J.86A.088...
Community Manager
Well no one responded to my problem today....well that's OK .
I went to my System Builder today and told them the whole story. Since the system is under warranty, they recommended I bring it to their store. They will run a full diagnostic and if they also can not get it working with 24GB they will replace the motherboard. I hope they can get it to work.
Community Manager
Hello Leslie, The motherboard is indeed capable of running 24GB of RAM memory and also the processor that has the memory controller built in. If you are having problems when using more than 16GB of memory, the problem could be the motherboard or the processor so having them tested by the computer shop will be a good idea as they can test another processor in your system.
Now I do recommend you to check your memory as the processor is rated to support memory up to 1066MHz and the memory that you purchased does not seem to support that frequency. As you tested the other Samsung* memory, the issue that you are currently having may not be related but using the memory out of specifications can bring on other problems in the future.
Regards.
