Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
DX58SO2 motherboard problems
Just bought a new computer with the DX58SO2 motherboard. I hooked it up and whenever I try starting it up, I get 3 beeps in sucsession, the K Led (dog fire) and the F (memory initialization) is lighting up.
I unhooked all the spec's and tried only with the CPU running, without the case, and its still the same. The post code has also went from 83(consistent) to 71.
Running:
ssd sata 120gb
i7 960
2xgeforce gtx 560
corsair intel i7 12gb(4x3) ddr3 1600mhz cl9
cooler master silent pro atx V12 2.3 850W
I haven't gotten to install the drivers yet, the beeps are disturbing, but he computer doesn't shut down.
Highlighted
Honored Contributor I
1 View
Re: DX58SO2 motherboard problems
The 3 beeps indicate a memory problem . could be one bad stick . try starting computer with only one ram stick see what happens.
