Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
DX79SI Not booting to OS. Post error on screen shows 0_
Hi Gurus,
We had integrated a system with Intel DX79SI, Intel 3960X, 4x8GB RAM, Asus HD7970 DC2T-3GD5 GPU, Adaptec 6405 RAID Controller, 4 SAS Drives, DVD RW, 1000W Cooler Master PSU etc. On Powering up the system, the POST screen along with system details RAID config etc and freezes with 0_ post error on screen. The On board Diagnostic LED show 00. But system does not boot to OS. The display shows 0_ on right bottom. The same graphic card and other components are functional with Asus Rampage iv extreme. The BIOS ver is 553.
Kindly advice and help to find a solution.
Thanks in advance.
Highlighted
Tried a USB boot but no luck
Highlighted
I just now updated the bios and I still get that error
Highlighted
Hi iiiBolesiii.
Please clarify something, by "fresh install" you mean that you are installing a completely new operating system installation, correct? Also have you tried a formatted drive?
Highlighted
I'm Also having the same issue with a DP55WB. Was running fine with a Radon 4350 went to upgrade the graphics card and now I get this issue. Tried with both and AMD rx570 and Nvidia 1650
I've already updated to the latest bios and still no go.
