Community
cancel
Showing results for
Search instead for
Did you mean:
freit1
DX79SI + PCIe payload size
Jump to solution
Hi all,
we've got a new issue starting with the last but one BIOS version. Up to version 515 the BIOS supported setting the PCI express payload size. This setting is mandatory for a third party plugin card (Silicon Software ME4 frame grabber) we're using in our systems. Current BIOS limits this setting, which in turn cuts down the performance of the grabber card. None of the readmes of the newer BIOS versions tells about this limitation.
Please turn off this limitation!
Franz
Accepted Solutions
Community Manager
Hello Fx,
We will make sure your comment reaches the proper department for future consideration. Thank you for taking the time to communicate this issue to us.
Community Manager
Hello Fx,
freit1
Hello Dan_Intel,
thanks for reporting! We've tested the latest BIOS 553 and it works again.
Franz
