Intel® Desktop Boards
Peer-to-peer support only
11475 Discussions
DX79SI - USB3 - spread spectrum clocking
Community Manager
Hi there,
I have trouble with the DX79SI Mainboard and some external USB3 devices. For some USB3.0 devices, such as Cypress FX3, it is mandatory to disable the Spread spectrum clocking on host side, in order to work correctly. How can I disable the Spread spectrum Clocking in the latest BIOS version 0553(2012/10/27)? In case it is not possible, is this function available in an old bios version or with another tool?
Sebastian
Community Manager
Dear Intel support team,
I am still looking for an answer.
In the meantime we found some additional information:
Source: http://www.eepublishers.co.za/article/usb-3-0-shaking-up-the-status-quo.html EE Publishers - USB 3.0: Shaking up the status quo
"Some motherboards improperly implement centre-spread SSC clocking, which violates the USB 3.0 specification requirements. Centre-spread profiles are centered on the nominal frequency and are modulated above and below by equal amounts, for example +2500/-2500 ppm. Most USB 3.0 devices are not compatible with systems that improperly implement center-spread SSC. When consumers purchase host add-in cards and add them to a system that has a noncompliant system clock, they will be disappointed."
How did you realise the SSC on the DX79SI motherboard?
How can I disable the Spread spectrum Clocking? In case it is not possible, is this function available in an old bios version or with another tool?
Sebastian
Community Manager
Hello Sebastian,
The Intel(R) Desktop Board DX79SI is compliant with the USB 3.0 standards and there is no option to disable
Spread spectrum Clocking or has been or earlier BIOS versions.
Regards.
