Community
cancel
Showing results for
Search instead for
Did you mean:
DX79SI What is the Firewire Chipset used on the Board?
Jump to solution
Hi I want to buy the DX79SI motherboard but I need to know the chipset used for the 2 Firewire ports on this board
I do have experience some weird behaviours with some chipser so I just want to make sure the ones installed on this board are compatible with my Audio Card (RME Fireface UFX
Thanks for your help
Accepted Solutions
Highlighted
Hello Saxfred,
Based on the Block diagram of the Technical product specification of this board, the IEEE-1394A (Fire wire) comes directly from the PCH-X79. You can see that information on the following link page 15.
http://www.intel.com/support/motherboards/desktop/dx79si/sb/CS-032850.htm http://www.intel.com/support/motherboards/desktop/dx79si/sb/CS-032850.htm
Regarding the audio card you want to use, we have researched and no one has tested that device on our motherboards. So, you would need to contact the system manufacture to check if it is compatible with our product.
Regards.
Highlighted
Any feedback please?
Highlighted
Hello Saxfred,
Regards.
