Intel® Desktop Boards
Peer-to-peer support only
11475 Discussions
DX79SI memory timing question
Community Manager
My quest is a rather simple one involving the DX79SI mobo, is the G.SKILL Ripjaws Z Series 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200) Model F3-19200CL10Q-32GBZHD of 10-12-12-31 compatible with the aforementioned board. I'm having perodic lock up when opening programs up in Windows 7 SP 1 64-bit.
RRamo7
New Contributor III
Hi Daichi Azure,
We would like to let you know that the memory controller hub has been moved to the processor, so the RAM memory you will use depends on what the processor supports.
So since you are using the DX79SI motherboard, and assuming you are using a 3rd gen Intel® processor, the maximum speed you can is 1600MHz at 1.5 volts. Make sure these are the settings you have in your BIOS.
Community Manager
They are. It's just that after a while the PC locks up when it's been running for a while when flash/java heavy things have been running...or when I load a game up after it's finished booting, i'm just trying to eliminate hardware before software...
ZAgha
New Contributor II
Mr. Daichi,
I know how frustrating your problem is. However, If you pls send us a detailed description about your PC "ie. hardware". Any OCing???
Does the Freeze ups occur only when you enter the RAM timing manually and/or using the XMP?
First let us start by a detailed list of your hardware & sys configuration pls
Community Manager
DxDiag.txt contents:
System Information
Time of this report: 3/26/2013, 10:11:33
Machine name: DAICHI
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130104-1431)
Language: English (Regional Setting: English)
System Manufacturer: INTEL_
System Model: DX79SI__
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i7-3970X CPU @ 3.50GHz (12 CPUs), ~3.2GHz
Memory: 32768MB RAM
Available OS Memory: 32692MB RAM
Page File: 4167MB used, 61214MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 660
Manufacturer: NVIDIA
Chip type: GeForce GTX 660
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_11C0&SUBSYS_26673842&REV_A1
Display Memory: 2721 MB
Dedicated Memory: 3015 MB
Shared Memory: 3802 MB
Current Mode: 1600 x 900 (32 bit) (60Hz)
Monitor Name: HP 2009 Series Wide LCD Monitor
Monitor Model: HP 2009
Monitor Id: HWP2828
Native Mode: 1600 x 900(p) (60.000Hz)
Output Type: DVI
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 9.18.0013.1422 (English)
Driver Version: 9.18.13.1422
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 3/15/2013 00:53:06, 17990800 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-5280-11CF-7C5E-6A061CC2C435}
Vendor ID: 0x10DE
Device ID: 0x11C0
SubSys ID: 0x26673842
Revision ID: 0x00A1
Driver Strong Name: oem21.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section062:9.18.13.1422:pci\ven_10de&dev_11c0
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Forma...
Community Manager
Hello Daichi,
I don't see any problems with your configuration nor on the report.
Currently the issues that you are experiencing can be caused by any device on your system like the memory, the video card, the processor or the motherboard.
I suggest you to test the processor using the Intel® Processor Diagnostic Tool
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%C2%AE%20Processor%20Diagnos... http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%C2%AE%20Processor%20Diagnos...
If the processor test passes, I recommend you to test with memory that is natively 1600MHz at 1.5v and using a different video card.
Also make sure that your BIOS is up to date and the video card drivers are the latest.
Regards.
Community Manager
Alright, the Video driver is updated to the newest one and below are the results from the test...it read PASSED just a heads up
--- IPDT64 - rev 1.24.0.0 ---
--- Start Time: 03/31/2013 22:57:33---
--- Skipping Config ---
--- Reading CPU Manufacturer ---
Expected --> GenuineIntel
Detected --> GenuineIntel
Found --- Genuine Intel Processor ---
--- Temperature Test ---
Temperature Test Passed!!!
Temperature = 53 degrees C below maximum.
--- Reading Brand String ---
Detected Brand String:
Intel Core i7-3970X 3.50GHz
Brand String Test Passed!!!
--- Reading CPU Frequency ---
Expected CPU Frequency is --> 3.50
Detected CPU Frequency is --> 3.20427
CPU Frequency Test Passed with Warning!!!
The processor frequency could be affected by over-clocking or power management
features. Intel(R) does not support over-clocking of its processors.
Over-clocking is not compatible with the Intel(R) Processor Diagnostic Tool.
In order to ensure the processor frequency is not affected by these, please
enter BIOS and load defaults and disable any 'Over-Clocking' or power
management features that may be affecting processor frequency. Also please set
any software applications which control power management features to default.
--- FSB NOT Supported on this Processor ---
--- Running Base Clock test ---
Detected Base Clock --> 100
Base Clock test Pass ---
--- Running Floating Point test ---
Million Floating Points per Second, MFLOPS --> 475.2
Floating Point Test Pass ---
--- Running Prime Number Generation Test ---
Operation Per Second--> 5.98121e+006
Prime Number Generation Test Pass ---
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 1 x 32
- Detected L1 Inst Cache Size --> 1 x 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 15360
Cache Size Test Passed!!!
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
MMX SSE Testing Passed !!
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> Yes
AVX OS Support - AVX Operating System Supported --> Yes
AES - Advanced Encryption Standard Supported --> Yes
PCLMULQDQ - Polys Carry-Less Multiply Supported --> Yes
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- PASS
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
AVX AES PCLMULQDQ Testing Passed !!
--- Reading Memory Size ---
Detected Memory Size is --> 32.00GB
--- Integrated Memory Controller Stress Test ---
--- Integrated Memory Controller Stress Test Pass!!! ---
Integrated Memory Controller Test Pass!!!
Chipset : Intel(R) X79 Express Chipset or Intel(R) C600 Series Chipset
Chipset Stepping : C0
No device connected to PCI-to-PCI Bridge Controller
No device connected to PCI Express Port 0
No device connected to PCI Express Port 1
1 device connected to PCI Express Port 3
1 : VIA 1394 OHCI Compliant Host Controller
No device connected to PCI Express Port 4
1 device connected to PCI Express Port 6
1 : Intel(R) 82574L Gigabit Network Connection
4 device connected to SATA Controller 1
1 : HL-DT-ST BD-RE BH14NS40 ATA Device
2 : HL-DT-ST BD-RE BH14NS40 ATA Device
3 : WDC WD20EARX-00ZUDB0 ATA Device
4 : WDC WD20EARX-00ZUDB0 ATA Device
3USB devices detected
1 : USB Composite Device
2 : USB Composite Device
3 : USB Input Device
1 device connected to Intel High Definition Audio Controller
1 : High Definition Audio Device
PCH LAN Device 'Unknown Device. VEN:8086DEV:1502' detected
--- Platform Controller Hub Test Completed!!! ---
..Query 5..
--- Querying for Intel(R) Integrated Graphics Device (IGD) ---
..Intel(R) Integrated Graphics Device not supported on this processor..
..Skipping Intel(R) Integrated Graphics Device Presence Test..
--- CPU Load ---
--- Load Level = 8
CPU Load Passed!!!
Temperature = 40 degrees C below maximum.
--- Test End Time: 03/31/2013 23:01:33---
