Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
DX79SR Board Bluetooth adapter MS-3871 Windows 8.1
CShar5
Since I've had this DX79SR Desktop Board I've never been able to get the bluetooth device that came with it to work. Even to the point where I've given up, but every once in a while I try getting it to work again thinking maybe it was an issue that was eventually fixed. I'm not sure if it's because of Windows 8.1 or what.
Here is some of my issues. When I click on the Bluetooth icon in the system tray and go to "Show Bluetooth Devices" it goes to "PC Settings". Why would it go to PC Settings, if it's supposed to go to "Show Bluetooth Devices"? So I go to PC Settings and click on Devices, I see Bluetooth. I click on Bluetooth and try to connect to my phone and it constantly tries to connect / pair. Yet when I try to to do anything it says connection failed. My phone connects fine to other bluetooth devices, just not my computer one. Is there any chance that others had this problem and that it has been addressed?
Here are some things I've already tried. I tried installing this driver: Bluetooth: Motorola* Bluetooth 2.1+EDR USB Device (Bluetooth_allOS_3.0.2.285_PV_MSI.exe) While using this, I'd click the Bluetooth shortcut or click on Open My Bluetooth icon in the system tray and it would go straight to My Documents. Is it supposed to do that? I thought it was supposed to go to some kind of Manage Bluetooth area. Although it temporarily worked right after I installed it, but stops working everytime I reboot my computer. So I ended up uninstalling it and tried going back to the Generic Bluetooth Adapter, which doesn't work either.
So basically neither the Generic Bluetooth Adapter drivers or the drivers that this site has worked with my computer. Should I just give up on it again and consider it a lost cause? Maybe look for a new Bluetooth device that is compatible? One thing I keep thinking is that maybe this adapter is too out of date and I just need to give up and move on. Seems like I've tried everything, so this is one last resort before I just toss it and see if a new adapter would suit me better.
LVilc
baja actualizaciones del windows.
si tu bluetooth comenzó a dar fallas después de instalar algún programa desinstalalo
si tu bluetooth te funcionaba bien cuando vino de fabrica tu pc prueba formateando tu maquina.
Silvia_L_Intel1
Hello Fringelife, thanks for joining the Intel communities.
Regarding this behavior we know that if you use Bluetooth and WiFi module from boxed edition of motherboard, you should not need to install special drivers in Windows 8, the device should work with the drivers included on the operating system as Generic Bluetooth Adapter.
In addition please check if your board is using the latest BIOS version available which is 0650 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23825 Intel® Download Center
In case the issue persisted and if the motherboard is still under warranty, please get in touch with our Warranty team in order to replace it http://www.intel.com/p/en_US/support/contactsupport Contact Support or submit a web ticket at the following URL https://servicerequestmgmt.intel.com/webticketui/emailpage.aspx?lang=en-us Service Request Email
