Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
DX79SR and USB 3.0 Firmware Updates
I'm sure like most of you, your USB 3.0 ports are not working under Windows 8. When I saw the firmware updates dated 5/9/2013, I thought finally. Well after installing the update I can say they still don't work. I install both updates, front and rear. The front update processes fine...and those ports may work, but I don't have them hooked up. The rear update throws the message Device not found!
Any help to get this working under Windows 8, would be much appreciated.
Regards...
Tags (1)
Highlighted
Kevin, I'm not sure what the front panel has to do with the rear USB 3.0 ports, but here you go. There is a black plug, plugged into the blue 3.0 USB connector on the MB.
Also, as I suspected the back ports now are not working and the Renesas USB 3.0 eXtensible Host Controller - 0100 (Microsoft) is now missing.
Is there an inherent problem with these boards? I see the posting from others complaining about the same issue and I find it hard to believe 3 boards would exhibit the same behavior.
Tawn
Highlighted
Hi judochoke, I just need to clarify some information.
Is the system recognizing any USB 3.0 device at all?
Are the USB 2.0 ports working fine?
Based on your description, the USB controllers are being recognized randomly?
I would appreciate if you can post your dxdiag report here.
Highlighted
Kevin, the system does recognize the front USB 3.0 ports and all USB 2.0 ports. To answer your 3rd question, yes...it does appear the rear USB 3.0 ports are being recognized randomly. Since Sept. 7th, I have not seen the rear USB 3.0 ports be recognized again though.
To try a different OS I installed Windows 8.1 RTM (not preview). I've attached the DXDIAG from that install.
What could be causing the rear ports not to work? Do I need to switch the board out yet again?
Regards...
System Information
Time of this report: 9/14/2013, 08:06:59
Machine name: WK181T
Operating System: Windows 8.1 Pro 64-bit (6.3, Build 9600) (9600.winblue_rtm.130821-1623)
Language: English (Regional Setting: English)
System Manufacturer: INTEL_
System Model: DX79SR__
BIOS: SIX7910J.86A.0590.2013.0717.2343
Processor: Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~3.2GHz
Memory: 32768MB RAM
Available OS Memory: 32692MB RAM
Page File: 2855MB used, 34956MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
Display Tab 1: The file nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Display Tab 2: The file nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 560
Manufacturer: NVIDIA
Chip type: GeForce GTX 560
DAC type: Integrated RAMDAC
Device Type: Full Device
Device Key: Enum\PCI\VEN_10DE&DEV_1201&SUBSYS_83B41043&REV_A1
Display Memory: 4044 MB
Dedicated Memory: 972 MB
Shared Memory: 3071 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: VE248
Monitor Id: ACI2494
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: DVI
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 9.18.0013.2680 (English)
Driver Version: 9.18.13.2680
DDI Version: 11
Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported by Graphics driver
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 8/18/2013 16:02:58, 15703176 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
Device Identifier: {D7B71E3E-5141-11CF-8B79-B9A31CC2C435}
Vendor ID: 0x10DE
Device ID: 0x1201
SubSys ID: 0x83B41043
Revision ID: 0x00A1
Driver Strong Name: oem1.inf:0f066de37528e2cb:Section032:9.18.13.2680:pci\ven_10de&dev_1201
Rank Of Driver: 00DA2001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
DXVA2 Modes: DXVA2_ModeMPEG2_IDCT DXVA2_ModeMPEG2_VLD DXVA2_ModeVC1_VLD DXVA2_ModeVC1_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4...
Highlighted
Hi judochoke,
Thanks for the information. I am going to check this with the development team. I will keep you posted.
Highlighted
Hi Kevin, anything from the development team?
Regards...
Highlighted
Hi judochoke,
Sorry for the delay. This has been escalated and they are checking into this issue.
Highlighted
Hi Kevin, wanted to check back and see if there were any new developments?
Regards...
Highlighted
Hi judochoke,
Sorry for the delay but there are no updates yet.
Highlighted
Hi Kevin, how about now? If there is no update, what are my options? There is clearly something wrong with the rear USB 3.0 ports on this line of motherboards.
Highlighted
Hi Kevin,
I have exactly the same problem with my DX79SR as judochoke. Sometimes the 4 USB 3.0 ports on the back are recognized, but mostly not. The Issue is OS independent, Linux and Windows 8 are affected.
I have the most recent EFI and updated the USB 3.0 firmware successfully, both didn't help.
Will there be a solution for this issue?
Highlighted
I am really sorry for this but I still have no updates on this case; however, it is important to mention that is escalated to the corresponding department and it is under investigation.
Highlighted
Hi Kevin, can I get an ETA on when an update will be given? It's been several weeks with nothing. Based on their no response I'm guessing there really is a problem otherwise there would have been some push back.
Like I mentioned before is there an option for a refund on the board from Intel?
Thank you…I appreciate you sticking with this and not dropping it. I wish more people had your good work ethic.
Highlighted
In the meantime I need we need to get more information about the system configuration you are using? Can you please tell us what devices, brand and model are being used to replicate this issue?
Please send to us all information about the boards and components used. You mentioned before that the issue appears randomly with the rear USB 3.0.
Have you found an easy way to replicate the issue to make it happen every time you try it or it is just not working at all at this time?
Highlighted
Hi Kevin, this is my setup: (let me know if there is something I missed that you need)
Motherboard: Intel DX79SR
CPU: Intel Core-i7 3820
Memory: Patriot Viper 3 – 4 x 8GB kit PV332G186C0Qk
Video: ASUS GeForce GTX 560
Operating System: Windows 8.1 Pro w/Media Center
CD/DVD: Sony Optiarc Blu-ray BD-5300s
HDDs: 2 x Corsair 120GB Force GT SSD and 1 x Seagate 500GB Hard drive
Power Supply: 750w Corsair
I haven't seen the rear ports work recently. I thought they would normally come to life on a fresh install of Windows. The last two times I reloaded the system the rear ports never appeared.
Thank you
Highlighted
My Setup:
CPU: i7 3930k
Memory: 4x 4GB Kingston HyperX 1600MHz DIMMs
Video: NVIDIA Corporation GF114 [GeForce GTX 560 Ti] (rev a1)
OS: Gentoo Linux, Windows 8.1
Optical: TEAC Bluray Drive
Storage: 2x Samsung SSD, 4 HDDs
PSU: NesteQ ASM Xzero
The rear USB 3.0 ports often work after booting into the BIOS setup and restoring the default values by pressing F9. After a reboot they have a change to be visible in the OS.
Highlighted
Hello judochoke,
If you try resetting the bios Settings to defaults as JJ42 did, is it working? Also, Can you please tell us what devices have you tried connecting in the USB 3.0 ports?
JJ42,
What steps do you need to take to replicate this issue? Based on what you said, the ports work fine when setting the defaults at the bios level so I am interested in knowing what you need to do to have the ports not working.
Highlighted
Hi Kevin,
I have a DX79TO motherboard. It's been replaced once already. I too have rear USB 3 issues.
I've attempted upgrading the firmware as it says it addresses the very issues i'm having. However, as previously reported, i get a "Device Not Found!" message when attempting to run the firmware updated.
I've found that if I boot my computer up with anything plugged into the rear USB 3 ports, The bios screen sites idle for around a minute before proceeding and upon windows loading, the Host Controller displays a yellow warning bang in the device list. If I boot the machine without plugging in any devices, it boots correctly and the USB3 ports work properly.
Highlighted
Hello Kevin,
Resetting the BIOS to defaults does not work 100% of the time.
I've mainly tried connecting 2.0 and 3.0 external storage devices.
Regards...
Highlighted
Hey guys,
I know this is frustrating for you when I keep asking for more information but at this point I need to know the following:
  1. What When booting with a device connected to the system, are the ports recognized? If so, is it with USB 2.0 or 3.0?
  2. What is the brand/ model of the external device you are using?
  3. Have you tested different cables for that device?
    4. Can I have the board revision (AA number only) please?
  4. Did you test the system outside of the chassis in a non-conducted surface?
  5. Have you tested a different Rear USB connection?
Highlighted
All USB2.0 ports work fine. I can boot with the external disk in a USB2.0 port and have no issues. If I boot with the external disk in either of the 2 rear USB 3.0 ports, the bios POST screen sites idle for around a minute before continuing to boot into windows. Once windows has loaded, the "Renesas USB 3.0 eXtensible Hos Controller - 0096 (Microsoft)" device has a yellow bang icon and the hard disk will not be available in explorer. If you boot up without the external disk plugged into the USB 3.0 ports, the "Renesas USB 3.0 eXtensible Hos Controller - 0096 (Microsoft)" loads correctly and you can subsequently plug the external disk in after windows has loaded and use it properly.
The external disk is a 2TB Western Digital My Book Essential (p/n WDBACW0020HBK-01)
Unfortunately I only have the one compatible cable for the device. It is the only USB 3.0 device I own.
Model: DX79TO
Version: AAG28805-402
S/N: BTTO317001MP
BIOS Version: SIX7910J.86A.0590.2013.0717.2343
5. Did you test the system outside of the chassis in a non-conducted surface?
No, I would be fairly hesitant to do so.
6. Have you tested a different Rear USB connection?
I have tried both rear USB 3.0 ports and have the same issue regardless which one I use. As stated previously, the rear USB 2.0 ports have no problems.
