Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
DX79SR powers on again after forced power off
If you start the computer, then before the first bios screen appears, press and hold the power button to force the computer off, the computer will power down, but then a few seconds after the fans have stopped spinning, power back on again by itself.
The only way to stop the computer is to either wait until the first bios screen appears or switch the psu power off.
This does not happen on the Gigabyte Assassin 2 m/b [same chipset]
Community Manager
I should also note that on several occassions to date, that even with bios set to 'stay off' on power fail/resume, that when the psu is turned on, the board will self start anyway.
