Intel® Desktop Boards
Peer-to-peer support only
11475 Discussions
DX79SR: the diagnostic led "cpu hot" flashes a red light
李先生
The diagnostic led "cpu hot" flashes a red light,can not boot. and post-code led is no display.
But the memory ,Graphics card,fan,radiator connected properly. and fan is work fine.
And the machine worked fine before once replace the silicone......
Is cpu or board broken ? If ture which one is it
looking forward to a reply Ths!!
n_scott_pearson
Super User Retired Employee
I suggest that you remove the processor and then install it again. Also remove the memory DIMMs and then insert them again, ensuring that they are properly seated.
Hope this helps,
