Intel® Desktop Boards
Peer-to-peer support only
11435 Discussions
DX79TO: USB3 Hub-Problem and/or Bios Maintenaince Problem
WHoeh
I've bought a new monitor: a HP Z27i, that has an integrated USB3.0-Hub;
(http://h10010.www1.hp.com/wwpc/pscmisc/vac/us/product_pdfs/HP_Z27i_Datasheet.pdf http://h10010.www1.hp.com/wwpc/pscmisc/vac/us/product_pdfs/HP_Z27i_Datasheet.pdf)
when I plug in the USB cable into one of the two USB3-Ports on the rear,
the operating system (Windows) detects a 'Renesas Electronics USB 2.0 Hub' and doesn't function anyway;
when I plug in the USB cable into any USB2.0-Port,
the operating system (Windows) detects a 'Generic USB Hub', and everything works fine,
but only with USB 2.0 speed ...
(would there be a workaround like this: installing another USB 3.0 controller into a PCIe x1 slot
with a different chipset - I tested this USB 3.0 hub on my other computer that has a different USB 3.0 controller on board and
detects a 'Generic USB Hub' as expected)
the other problem, when I power on the computer there isn't shown any start screen
(Intel logo plus the menu keys - F2, F9, F10, ...)
the graphics card is the same as before, the only difference: before the old monitor was connected
with a Single-Link-DVI cable and this new one is connected with a Dual-Link-DVI cable;
please can someone help me for a solution on how to get the start screen back;
Walter
Silvia_L_Intel1
Hello Walter, the behavior you are experiencing could be a compatibility problem between the Board and the USB3.0 of your monitor. I suggest you to install the latest USB3.0 driver available for your motherboard and test a different device on it just to verify if it is working as expected. https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=19880 Intel® Download Center
You may test a regular 3.0 flash drive, and check if it is running at that speed.
Regarding the issue with the start screen, I would recommend you to do a clear CMOS on your board.
  • You can also test another monitor
  • Check the TV or monitor source is HDMI, VGA or DVI, depends on the video card you are using.
  • You can try doing a BIOS update. If the current BIOS version is the latest one available, you can try to reinstall it. https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23825 Intel® Download Center
WHoeh
I'm already using this latest USB 3.0 driver and my USB 3.0 flash drive runs with about 150 MByte/sec - the expected speed;
how can this compatibilty problem between the Board and the USB 3.0 of the monitor be solved?
my video card is a nVIDIA Quadro FX 380
(http://www.nvidia.com/docs/IO/68254/NV_DS_QFX_380_US_Mar09_FINAL_LoRes.pdf http://www.nvidia.com/docs/IO/68254/NV_DS_QFX_380_US_Mar09_FINAL_LoRes.pdf)
the monitor I had before (a 24" HP with 1920x1200) showed the start screen;
how can this be influenced whether this is shown or not?
is the CMOS cleared by the jumper on the board that is put the other way for a short time?
Walter
Silvia_L_Intel1
Walter, we tried to make as many third party components compatible as possible, but do to the sheer quantity of these third party components we cannot always guarantee compatibility. I suggest you checking if you are maybe missing the USB 3.0 drivers from the tv.
Regarding the CMOS, please follow these instructions. http://www.intel.com/cd/channel/reseller/emea/eng/membership/411560.htm How do I clear the CMOS?
This other link will give you a list of troubleshooting related to your board http://www.intel.com/p/en_US/support/category/dsktpboards/db-dx79to/trblsht Troubleshooting for the Intel® Desktop Board DX79TO
