Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
DX79TO mobo always goes to bios saying BACK2BIOS button is activated
I have been using this DX79TO mobo for many years with the same intel I7 and other hardware components as well. One day there was smoke in my mobo and a burn smell. After that, when i boot, the computer always goes to the bios and there is a message that the back2bios button is activated (red) and that i should press it and reboot. The back2bios button is NOT activated and is not stuck. As i said, i have been using this mobo for many years and everything always worked. The smoke came from a place near the CPU. I talked to an engineer and he said that it seems that a capacitor might have burnt, and that this one might control "the sensitivity to the back2bios button", lets put it that way because he used a specific term that i don't remember.
I tried to reset the CMOS with the jumper, either taking it out or putting it on the configure button. I also tried resseting the bios by pressing F7 on boot, but there isn´t an option to load an alternative bios. Resseting the bios to default also did nothing. Also tried taking out the CMOS battery which would have the same effect of resseting the bios to default. I guess this hardware problem won't be solved by changing anything in the bios.
It seems very radical, but removing (extracting by force) the back2bios button from the mobo could be a solution ?
Is there a bios option to ignore the back2bios button ? I guess not, because i have never seen something like that in the bios options...
Tags (1)
Highlighted
Super User Retired Employee
The damage caused by a failing component can be profound - and extend well beyond that individual component (a short especially, can affect many things). I doubt that removal of the B2B Button will make any difference at all - but feel free to try anything you want; I understand that replacing this board will be costly.
No, there is no option to ignore the B2B button. It is a recovery capability that is supposed to override any BIOS Settings.
Highlighted
Community Manager
Hello GamerZZ,
In regard to your concern for the "Back to BIOS", please refer to the following thread: /thread/31839 https://communities.intel.com/thread/31839. There you will be able to find some information that may come in handy for you.
In regard to the smoke, please try with your equipment "turn off " try to see if there seems to be any part burn or different.
Also if you have a chance please try to run the https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool Intel® Processor Diagnostic Tool.
Please let me know how it goes.
Hope I can hear from you soon.
Angie
Well, yesterday i was able to update the bios version of that computer to the latest (650), although i already had updated to this bios version a long time ago before this problem occurred. I did that just to check if it would make any difference but it didn't, the computer still doesn't try to load any OS because it thinks the B2B button is pressed, and it isn't. I'm not even using the shield (aluminum plate) so the button is not stuck and is not red.
I should note that before that i tried to update the bios by using the BIO file on a cd on an external usb dvd-drive because i don't have an internal dvd-drive, and was not able to do that when pressing F7 on boot, because the external dvd-drive was not recognized on the F7 bios recovery procedure. Yesterday i was able to update the bios using an usb thumb drive, so that means the F7 recovery procedure works with the usb thumb drive, probably works with an internal dvd-drive BUT doesn't work with an EXTERNAL dvd-drive. I think Intel could improve on that procedure if possible. That is also applicable to the procedure of changing the CMOS jumper to the configuration position or just taking the jumper out.
About the Intel Processor Diagnostic Tool, i'm not able to use it because that computer doesn't load any OS and i don't have any other compatible mobo for my I7 3930...
Highlighted
Community Manager
Hello GamerZZ,
I have sent a private message in regard to your concern.
Angie
Highlighted
Thanks Angie. I was going to send jpgs with the things you asked but i don't see an option to send appended files in the inbox...should i post it here ?
Highlighted
Community Manager
Hello GamerZZ,
I just sent you a private message.
I will be waiting for your response.
Juan Carlos
Highlighted
Community Manager
Hello GamerZZ,
I have sent you a private message.
Juan Carlos
