Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
DZ68BC Bios 39
SK18
BIOS 39 for DZ68BC is now available.
According to the release notes, the changes are
New Fixes/Features:
• Fixed issue where hard disk drive is not recognized when SATA mode is set to AHCI.
• Updated processor support.
• Updated VBIOS.
So I'm not overly hopeful that it fixes the other issues we have been experiencing (but I suppose the last two items are pretty vague and could mean just about anything)
My board is still in its box, where its resided since I fixed my PC build with a Gigabyte board (that worked!) .... The question is it it worth dusting it off and building a second new PC from it and my other spare parts.....
Hmmmm.....
Link http://downloadcenter.intel.com/Detail_Desc.aspx?ProductID=3381&DwnldID=22159&lang=eng&iid=dc_rss http://downloadcenter.intel.com/Detail_Desc.aspx?ProductID=3381&DwnldID=22159&lang=eng
VDerk
New Contributor III
Just installed 0039 on my DZ68BC, revision AAG30742-401 with a i7 2600K with the F7 method.
BIOS installed ok. Didn't see the "unknown processor screen" yet (issue introduced with 0037). Will do some more testing coming days.
Community Manager
Just try to install 0039 (0035>0039). My board is rev 401. Processor i5-2500K.
I have a "uknown processor screen". ME is stil 0.0.0.0... rollback on 0035.
Stephen
Valued Contributor I
Check this out,
Currently running on 0039, all is well for me while using my procedure but the sad truth is the Intel ME 0.0.0.0 Brought by 0035 and PCH 0.0. Issue Brought by BIOS 0037 are still present but there is a permanent workaround to make the work correctly. first if you are using Blue DIMMs as stated by the manual as recommend ignore that and use the Black DIMMs thats if you have 2 Memory sticks or 1 so use method below
Oh Populate only the first Black DIMM and live the others empty then if it works add the second stick to the remaining Black DIMM and you are good to go no issues.
Safest RAM Configuration is, first ignore the blue ones as primary DIMMs i assume this goes for Ivy Bridge users only I guess the primary DIMMs using Ivy Bridge are Black.
So for those using 1 RAM stick populate the first Black DIMM from the CPU side.
For those using 2 RAM Sticks populate the 2 Black DIMMs
For those using 3 RAM Sticks populate the 2 Black DIMMs and the first Blue DIMM from the CPU side
For those using 4 RAM Sticks its a no brainier populate all DIMMs all should be well, no issue there.
this tests have Been done using Ivy Bridge CPU and those scenarios produce working conditions with BIOS 0039 the Intel ME and PCH issue not present with those configurations.
Intel ME PCH issue present while using only the Blue DIMMs or while not using the first Black DIMM after the CPU. Simply put the First Black DIMM is the Key DIMM while using Ivy Bridge, Never had any issues with Sandy Bridge the only issue was when 0035 displayed wrong values but then i was changing to Ivy Bridge so i needed the 0035 BIOS.
Community Manager
Thank you Stephenb.b.r for workaround. BIOS 0039, ME now 8.0.13.1502, after changing memory slots from blue to black. But my "old" i5-2500K is still "unknown processor"...
I'm "wondering" again...
VDerk
New Contributor III
I used to have the same "unknown processor" problem with BIOS 0037 and my i7-2600K. Somehow it resolved itself and it didn't came back in 0039. I have no clue what resolved it. I disabled/enabled UEFI to flash my Crucial M4 SSD to the 10G firmware but that would be a strange trigger...
My ME version lists 7.1.52.1176. Does somebody know how the BIOS decides which revision to use? (the readme stats that both 7.1.52.1176 and 8.0.13.1502 are included. I thought that ME v8 was for Ivy bridge, but now it seems it also to work with an i5-2500K on a 401 revision board?
Stephen
The work around works for BIOS 0035, 0036, 0037 & 0039
In your case about the "unknown processor" 0036 & 0035 dint have this issue ad 0036 is better than 0035, so if you are to roll back use 0036 but id suggest stay on 0039 it might resolve it self as vbaderks has said.
Stephen
I'd very much curious on how the BIOS decides which version of Intel ME to install apart from the obvious processor architecture that could be the trigger.
How the BIOS decides might have a glitch that causes the Intel ME to act abnormal and show 0.0.0.0, who knows what goes on! I'd very much like to know how this happens.
Community Manager
We have had all kinds of stability issues with the board and bios. We also have only been able to solve all the issues with a different board. My most recent build with 37 seemed to be stable for the last week but then today the video on it died. Its not the first time I've had the no video issue with this board. I've tried the HDMI port, display port, and an addon card. Nothing. No even POST messages. The error and beep codes have gone away so the machine thinks everything is AOK with 39 (I did the recovery update process since I didn't have video) but still no video. I'm open to suggestions.
Stephen
So the 0037 is the rout of the video problems on the DZ68BC according to the tests i did with all the 003x BIOS from 0035, 0036,0037 & now on 0039.
The video problems originate from the 0037 BIOS this is a fact.
So to try and help you, if you can down grade the DZ68BC BIOS to either 0036 or 0035 and see if it will come back to life since those BIOS dint have video issue they only had other horrible issues but at list a machine can be up and running, if the above works then maybe skip 0037 afterwards and straight to 0039.
Maybe try using a PCI legacy VGA Card.
Plus maybe to get it up again remove all the things attached to the board except CPU, remove all the ram, HDDs and any other thing then remove the CMOS battery for like 5 - 10m then reattach them back, note with the RAM remove all sticks and use the first black DIMM next to the CPU it appears to behave as the Key DIMM only use One Ram stick at that point and then if all goes well add the rest.
Community Manager
Man Intel you guys suck. After reading this I'll stick with 0028. I see it's the same crowd that has had issues in the past. This board is JUNK! Even with 0028 I'll power the computer on sometimes to find out that the BIOS has reset itself and lost all of my settings. Just think guys and gals when Broadwell gets here we might all be forced to use Intel boards.
http://www.legitreviews.com/news/14561/ Intel Broadwell CPUs To Use BGA Package - Get Ready For The SOC Revolution
BF_
New Contributor II
Relative to what version? I've seen one drive drop out of the BIOS a couple times in 0028 over the time I've been using it (most of the year), and I was thinking that it was a failing drive, but finding this in the release notes gives me pause.
Community Manager
I am on 0039 too, the only thing it got solved is the Marvell/Ahci.
I am still unable to OC my i5 3570K, and verything is greyed out, even i dont have the field to manually select my memory speed...
Truth is, this MOBO has been a huge disappointment, and i dont have any chance of RMA (cos´ Intel does no say a word bout this, so, it is no ´malcfunction´) and they´re dropping it...
So, im stuck with a limited Board, and CERO advantages of having an Unlocked K Procesor... a shame, really...
I wish that a 0040+ version comes out solving all the OC, Host Freq, Memory, etc, issues this Mobo has.
Extreme series???... yeha... sure... :/
BF_
New Contributor II
John, I was asking about the AHCI thing before--what was the problem, exactly, and as of what version did it start (it would be nice to know)? I guess you're saying that it pertains only to Marvel?
Community Manager
Indeed, i always had a 3570k, so, no v0028 for.
Since day cero, with 0035 and up to 0038, if i had a SATAIII drive in the light blue conectors (Marvell) in AHCI mode, windows never got to start, or crashed during load, o it started, but was riduculously SLOW, with freezes an lag etc. So, had to revert to IDE, Legacy.
Now i can work in AHCI (still, did not had the chance to do some quicks benchs to see if there is any significant difference)
Eitherway, was one of the many things supposed to work... but that never worked. Now at least, it does.
BF_
New Contributor II
Eek, that's not good, but I'm curious why you were using that controller at all when you had 6 non-Marvel ports to choose from?
Community Manager
Cos´ just 4 are SATAIII/6GB (two from Intel, and the other 2 from Marvell) and i have 3 SATAIII/6GB HDDs (4 HDDs in total, but one is SATA2)
Community Manager
Hi there!
Unfortunately I also decided to get the DZ68BC because of 3x PCI / 8x SATA / FireWire. It was shipped by Amazon just last week in the 402 revision ( ! ) and of course I ran into all the problems mentioned here. I wanted to use it with an i7/3770K so I had to get a Sandy Bridge Celeron for the BIOS update to v39. Since then only problems. Board sometimes stucks at POST 20 (changed only one DIMM to another slot to solve this) or POST Eb with two beeps and no screen (only "blind flash" with "jumper open" method helps in this case), especially after Windows 7 hibernation. In a few cases the board tries to resume from S4 but Windows complains about a configuration change on the board and stops resuming with an error code 0xc00004111. (Maybe this can be fixed by reinstalling Windows - I tried to use an old installation image from a P965 based board.)
Sometimes of course Windows also complains about missing MEI: in device manager.
Someone from the community mentioned that they changed something on the hardware revision 403 to make to board more stable. Can anyone confirm that board revision 403 or 404 is running more reliable than the 402 revision (mine is made on April 12th 2012 - rev 402 as mentioned)? Maybe there's a chance that intel will replace my board with the a newer revision?
Else I'll send it back to Amazon and get something reliable...
Kind regards
Chris
VDerk
New Contributor III
The different revisions are documented in the Intel PCN database (search for DZ68BC). In short:
G30742-400 = original (not sold?)
G30742-401 = BIOS 0021
G30742-402 = BIOS 0028 Improve power capability for USB keyboard/mouse + enhanced PSU compatibility.
G30742-403 = BIOS 0034 add Resistors for DIMM Voltage Reference
G30742-404 = BIOS 0038 no hardware change (PCN mentioned 0038, actual revision number was 0039)
Re-using an old installation image is most of the time not a good plan. Doing a fresh install and install the latest Intel drivers will provide a much better OS installation. I think that will solve the sleep problem. The MEI problem in the device manager can be resolved by installing the Intel Management ME 8 driver. This will install also some background services. Uninstalling ME after the install and a restart will still allow Window to detect the device properly (the ME software is primary intended to manage systems remote by a IT organization)
The POST 20 and Eb issues are a different story. I would read the feedback on this forum and combine that with your personal experience with this board...
ECava1
Hello Intel Team and experts here.
Well, I have a computer I made about 3 years ago with Intel DZ68BC with BIOS 28
Intel i7 2600k
Kingston memories 16 gigas ( I used the ones on the intel motherboard list )
Windows 7 PRO 64 bits.
SSD intel 510 series 120 gigas.
Power supply Corsair 850 w.
The fact is my computer never worked well. I spent a lot of money to buit it. The computer looks like wants to frozen all the time, sometimes when I'm typing text gives me the impression that fought for a second and then skips letters.
When I use simple 3D features, OMG, it is a caos, even using my AMD HD 7970.
Even the SIMPLE second life www.secondlife.com that works perfect on INTEL IRIS, it frozen in my system with a powerfull videoboard as 7970, the best before the R9s ones.
PLease, I need a solution.
WHAT IS the best BIOS for this motherboard? The one I HAVE? 39? the latest? PLease user, please Intel, Please experts, I really need a help. please. I am suffering with it.
What I need for this machine works better? Should I update the bios? there any BIOS stable and better then the BIOS 28 ??
I will use the same hardware I described
Community Manager
Piece of advice:
RMA that crappy DZ68BC.
I returned mine to the store. I am happy Asus user now. No instability problems anymore.
