This morning during a normal initial boot i received an E6 error code displayed on the DZ68BC motherboard. I do have ATT-Uverse internet service and i noticed on the ATT modem the ethernet led emitter light that normally blinks was not blinking and simply OFF. Not knowing if this could be the culprit i decided to disconnect all the desktop input peripheal cables and took the rig out for a thorough dust cleaning and re-seating of the video card, ram, and all other power supply and HD connections. Afterwards during the following boot the OS detected the normal detection of either a hardware or software change and i simply selected to perform a normal start-up. The Att -Uverse modem ethernet led emitter was now blinking normally and the computer started up just fine and everything appears to be normal with no codes displayed on the DZ68BC other then 00.
So my question is could the ethernet service being interrupted by ATT been the cause for the E6 error code or just reseating all the boards and internal desktop connections resolved the E6 error code issue ?
What does the E6 error code actually depict on the DZ68BC motherboard since it is not shown in the error code summary list provided by Intel that comes with this DZ68BC MB.
I built this rig below a few years ago and this is the first problem i have encountered thus far. I am still running the original Bios 021 that came with the DZ68BC and know NOT to perform any Bios update past the 028 version or the board will be totally useless. So running the existing 021 bios is not the culprit since it has run fine for 2 yrs.
Pc Specs:
Case: CM Storm Enforcer Midtower USB3.0 --- CPU : i7-2600K Mobo: Intel DZ68BC Extreme Ram : Corsair Vengeance pc1600/ 16gbVideo: EVGA Nvidia GTX 560ti HDD: SSD 120GB Intel 520 series & 1.5 TB WD Caviar Black Pwr.Supply: Rosewill Capstone 650watt Gold Rated 80+CPU Cooler: CM Hyper 212 EVO
Fans: 200mm front intake, 200mm top exhaust, 120mm rear exhaust NZXT Sentry Mesh 5.25 Bay Fan controller
ASUS DRW-24B1ST 24X DVD Burner
LG WH12LS30K 12X Bluray Burner/Player
AFT USB 3.0 Multi-Card reader 5.25 Bay
OS: Windows 7 64 bit
Monitor : LG 27EA83R-D 2560 x 1440p
Thanks for any help with exactly what the E6 error code can pertain to.
Regards, Ron
Hello Ron, the E6 code refers to the "connecting drivers" boot-up portion during POST; please check the following link:
http://www.intel.com/support/motherboards/desktop/sb/CS-025434.htm http://www.intel.com/support/motherboards/desktop/sb/CS-025434.htm
I would recommend you to test the system out of the chassis using minimal configuration. (Motherboard, processor, power supply and 1 memory stick). Please remove the video card.
Restore BIOS default settings. Reset any customized BIOS settings. Clear all DMI event logs by setting the option to "Enable", which is located in the Advanced/Event Log Configuration section of the BIOS Setup utility. Press to save the new settings and reboot the system.
Clear the CMOS if the error code still shows up:
http://www.intel.com/support/motherboards/desktop/sb/CS-010254.htm# bioschanges http://www.intel.com/support/motherboards/desktop/sb/CS-010254.htm# bioschanges
Note: Make sure you leave the battery out for 20 min., at least.
Start adding one component at the time until you find the conflicting one.
I know you are running the original BIOS version, but a BIOS update may help also.
