Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
DZ68BC problem with Corsair memory sticks
Community Manager
Hello All,
I have a DZ68BC Intel MoBo and somedays ago I got a Corsair memory kit P/N CMZ16GX3M4A1600C9B, and my MoBo doesn't work and beep 3 times. If I upgrade the BIOS, it`ll work with these memory modules? Someone had some issues with this MoBo?
VDerk
New Contributor III
A lot of people are having problems with the 003x versions of the BIOS. If you now have version 0028 I would sugest to read the forum posts (search for DZ68BC) and decide yourself. Once you upgrade from 0028 to a 003x version you cannot go back.
Community Manager
Try using just one DIMM. What CPU do you have installed?
Community Manager
Hi All,
Firstly, thank you for your quickly response.
vbarderks: i`ll try to upgrade the bios by myself as soon as i can boot the MoBo.
nails: I tried to use a single card but it's not work. I'm using a i5 3570K. I don't know what is the bios version and i'm thinking how can i will upgrade it without boot sequence or some other init screen.
Thanks again and best regards,
