Community
cancel
Showing results for
Search instead for
Did you mean:
ECava1
DZ68BC with BIOS 28 and having problems. Please, I need some help.
Hello Intel Team and experts here.
Well, I have a computer I made about 3 years ago with Intel DZ68BC with BIOS 28
Intel i7 2600k
Kingston memories 16 gigas ( I used the ones on the intel motherboard list )
Windows 7 PRO 64 bits.
SSD intel 510 series 120 gigas.
Power supply Corsair 850 w.
The fact is my computer never worked well. I spent a lot of money to buit it. The computer looks like wants to frozen all the time, sometimes when I'm typing text gives me the impression that fought for a second and then skips letters.
When I use simple 3D features, OMG, it is a caos, even using my AMD HD 7970.
Even the SIMPLE second life www.secondlife.com that works perfect on INTEL IRIS, it frozen in my system with a powerfull videoboard as 7970, the best before the R9s ones.
PLease, I need a solution.
WHAT IS the best BIOS for this motherboard? The one I HAVE? 39? the latest? PLease user, please Intel, Please experts, I really need a help. please. I am suffering with it.
What I need for this machine works better? Should I update the bios? there any BIOS stable and better then the BIOS 28 ??
I will use the same hardware I described
Tags (1)
ECava1
So.... I will make the last test.
Tell me please, the steps to
1) remove the video card,
2) Install the correct intel graphic drivers to test it
3) I will see if the MOBO works without the videocard to discard the possibility of PCI xpress interface.
I will try to find here in this topic the post with the intel graphics.
Thank you again
ECava1
OK, N.Scott.Pearson, paramountain, cesbadil, mikec_intel and all INTEL team.
O followed the steps and I removed the AMD graphics card; I did in this ordem.
1) I unstalled the drivers.
2) Turned off the windows
3) Turned off the computer from the electricity
4) removed the PCI power
5) Removed from the computer.
SO I restart again the computer and inslalled the intel Graphics for 2nd Generation of Intel processor and restarted.
In the windows the screen started to blink in so many colors. ANd I restarted the computer in BIOS mode ( so, in the mode doesnt use any windows drive, it is the BIOS)
and...
EVEN in BIOS mode the screen started to blinking too until crashes and everytime I start the computer is the same thing.
So... it is clear the problem is the MODO, i7 or the BIOS.
ECava1
So, I have no patiente for this problematic motherbord and I AM DECIDED a last try to fix it.
I will install the BIOS.
SO, which more reliable, stable bios who people here in this communities had good experiencies for this mother board?
37,39, 42? Another one?
ty
