Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
DZ68BC
Community Manager
New build using DZ68BC,Sandy bridge i5 2550K
Does 1600 speed memory work with 2nd generation configuration or is this1600 memory for the Ivy Bridge?
What suggestions does anyone have for memory for Sandy Bridge configuration.
Thanks In Advance
Community Manager
Only keep in mind that running the memory higher than 1333MHz will run the memory controller on the processor out of specifications and may damage it.
VDerk
New Contributor III
A good 1600 memory set should work. 1600 is above the "normal" spec, but most memory kits have a build in xmp profile for it. Manual configuration is also possible. You can even try higher, 1833 for example. My memory kit with this board and a i7 2600K does 1600 but fails to boot with 1833. My advice would be to run a memory test tool during the night to see if the setting is stable (there are many free tools available).
Community Manager
What type of memory do you have install I am considering Corsair
Also what version of bios is installed
Thank You for your reply
VDerk
New Contributor III
I have 4 * 4G Corsair CML16GX3M4A1600C9.
My bios version is 0039. If your on 0028 then I suggest first to read the posts on this forum about the 003x BIOS revisions, many people are having problems with the 003x revisions (including me)
Community Manager
Community Manager
Thanks for your replies.
I did keep in mind concerning the memory speed and purchased the Corsair XMS3,CML8GX3M2A1333C9
This will be my Configuration
DZ68BC Extreme Series
i5 2550K
Corsair 650W Power Supply
Hoping once assembled it will run,will post progress or problems when started
