Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
DZ68DB Bios 043 : Significant decrease performance
My computer is a Digital Audio Workstation.
I use it under windows 7
My mother board is a DZ68DB with a I7-2600K CPU.
On the two PCI Express 2.0 x1 connectors, i have plugged two IEEE1394 controller cards.
These firewire ports are used for two MOTU ULTRALITE soundcards.
Since i have updated the bios from version 032 to 043, I noticed a significant decrease in performance on PCI express bus.
The system regularly loses communication with the firewire devices. They suddenly disappear and i must to restart them.
I did not have this problem before the bios update.
Can you help me?
By the way, how to downgrade to the 032 bios version ?
Thank you for your support.
Best regards.
Tags (1)
PWert
Valued Contributor I
Hi - I can not help you with the performance issue; but, BIOS recovery procedures are found here - http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm. Regards. Peter
