I reinstalled my PC from scratch with Win8.1 and after that, the RTC doesn't work anymore. When you are in the BIOS, the RTC is not ticking. And if the PC is off for some time, the clock misses this time.
I've allready changed the CMOS battery with no effekt.
I don't think it's an hardware issue, because it would be a great coincidence that it just happened during reinstallation of win8.1
Does anyone have any idea?
regards andi
- Tags:
- HP Workstations
Hi andi, did you try measuring the voltage of the new battery just in case it is bad too? I hope you have a multimeter.
I would not imagine this to be related to the operating system but perhaps you may want to try a different image or operating system altogether. It may help to try a http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm BIOS recovery as well.
I wonder if anything else changed in your hardware that could have caused this.
Hi Joe,
the new battery is fine and even the old one is still good. I also tried to flash the BIOS again, with no effect.
Finally I got the problem solved by booting Ubuntu 14.04 from an USB stick. After rebooting into the BIOS I recognized the clock now running again
Since then everything seems to work normally again.
Does this make any sense to you?
I am glad you got it working.
It did not make any sense first but now I suspect it is related to UTC vs the local time (GMT) configuration. It seems to be a common issue.
- http://www.cl.cam.ac.uk/~mgk25/mswish/ut-rtc.html IBM PC Real Time Clock should run in UT
- http://superuser.com/questions/494432/force-windows-8-to-use-utc-when-dealing-with-bios-clock Force Windows 8 to use UTC when dealing with BIOS clock - Super User
- https://bbs.archlinux.org/viewtopic.php?id=176976 https://bbs.archlinux.org/viewtopic.php?id=176976
- http://www.neowin.net/forum/topic/1198117-cmos-rtc-problem-windows-8-gateway/ CMOS RTC Problem - Windows 8 - Gateway - Hardware Hangout - Neowin Forums
