Intel® Desktop Boards
Peer-to-peer support only
11480 Discussions
DZ75ML-45K memory slots
IKlam
Hi everyone! Could you help me a little bit please?
My DZ75ML-45K main board beeps 3 times with memory error when i trying to install in DIMM2 slot this memory kingstone hx316c10fb/8 (8 GB RAM). Memory works fine in other slots.
In other slots this and same memory works fine. When i installed in DIMM2 4GB RAM computer works fine with 28 GB RAM.
What could be the problem?
thanks in advance for answers.
Best regards, Ivan.
IKlam
And nothing more can be done?
AlHill
What is your current bios?
Doc
IKlam
MLZ7510H.86A.0017.2013.0516.1246, 16.05.2013
AlHill
Well, you are on bios 0017, which is the latest for your board.
Have you tried different memory?
Doc
IKlam
Yes, I have 4 different memory bars of kingstone hx316c10fb/8 and i tried them all
AlHill
Memory other than what you have (non-Kingston)?
Doc
n_scott_pearson
Super User Retired Employee
What memory were you using previous to this set?
To me, it is looking like this memory channel, when a DIMM of this type is present in this slot, is not working or is generating enough noise that the channel cannot operate properly. Your choices in this case are limited. You can replace the motherboard, you can replace the memory (I am not a fan of Kingston myself) or you can avoid using this type of DIMM in this slot [Aside: it would be better, memory performance wise, to run with 24GB rather than 28GB.]
Hope this helps,
