Intel® Desktop Boards
Peer-to-peer support only
11430 Discussions
DZ75ML-45K pcv and pch core voltage out of range
CTeod
I have attached two screenshots, can anybody help me with my intel desktop utilities error?
Processor core voltage 0.840 V - out of range
PCH core voltage 1.070 V - out of range
I have Intel desktop board DZ75ML-45K, intel core i3 3240 CPU, 8G Kingston memory 1333 Mhz, 128G SSD Kingston hyperx fury.
n_scott_pearson
Super User Retired Employee
There is no issue here; these are normal readings. It is likely that Intel Desktop Utilities is using too tight a range for reading validation.
Within Intel Desktop Utilities, go into Options and then Set Sensor Threshold. Near the bottom of the list, you will see the entries for these voltage sensors. Make the range for the sensors a little bit wider by raising the Upper limit and lowering the Lower limit.
Community Manager
Hi Riffer,
I have been checking this thread and I was wondering if the information provided helps you.
If there is anything else you need, do not heisted to contact us back.
Hellen.
