Hi.
I flashed the BIOS using F7 on my DZ77BH-55K from 0085 to 0097 version and it would not go past post after it was done.
After running the update, the PC said "successful" and shut down and then didn't come back on. Just black screen.
I tried to full recovery method with the BIO file on the root of a USB stick, plugged into a USB 2 port, with the jumper removed then powering up, but no results
CPU: i5 3330
RAM: HMT351U6CFR8C-PBN0
Post Code 15 on MoBo display
The Board Status LEDs were:
A, Hard Drive Activity = off
B, CPU Hot = on
C, VR Hot = off
D, Watch Dog Fire / Back to BIOS = off
E, CPU Initilization = off
F, Memory Initilization = off
G, Video Initilization = off
H, USB Initilization = off
I, Hard Drive Initilization = off
J, Option ROM Initilization = off
K, Operating System Start = off
Any suggestions welcome.
- Tags:
- File Recovery
Hello Russell, At this time you can try clearing the CMOS by removing the 2 power cables from the motherboard and taking the battery for 30 minutes, if the problem continues you should contact your local warranty department for replacement.
http://www.intel.com/p/en_US/support/contact/phone?redirector_count=1& http://www.intel.com/p/en_US/support/contact/phone?redirector_count=1&
Regards.
Regards.
Russell,
Have you resolved this problem?
I have identical one...
