Intel® Desktop Boards
Peer-to-peer support only
11476 Discussions
DZ77BH-55K BIOS audio can't be disabled.
Community Manager
I have BIOS 0099. When I uncheck the audio in the BIOS, it won't boot. I see the "Intel inside" screen and then it hangs. It doesn't display the function key menu. My guess is it wants to play the Intel jingle but it can't because the audio is disabled. So it just sits there.
The only way to recover is press the "back to BIOS" button. This gets me into the BIOS setup.
You can get to the audio enable/disable by clicking Devices >> Onboard Devices.
BIOS bug?
Anonymous
Not applicable
Hello Steve17,
Audio settings are not causing the problem. It seems to be a BIOS setting issue. My best recommendation is set the BIOS as default. Go to the BIOS, press F9 then yes, press F10 then yes.
Community Manager
I beg to differ. I set the defaults as you suggested. It worked fine. Then I unchecked the box for "Audio". I saved the change and restarted. The BIOS hung with the initial screen "Intel Inside" and did not show the function key menu. Nothing worked, not even ctrl-alt-del. Restarting didn't help. Still hung.
Only the back-to--BIOS button allowed me to get into the BIOS. I checked the box for "Audio" and I was back to normal.
Community Manager
This exercise was not in vain though. While restoring my BIOS settings after setting the defaults, I noticed the box for "Startup sounds". Unchecking that cured the LOUD Intel jingle, so now I'm happy.
