Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
DZ77BH-55K Updated to BIOS 0100 RAM Issue
HYu18
I recently updated my DZ77BH-55K board (3770K processor) to the new BIOS 0100 (05/17/2013) using Intel Integrator Toolkit. I updated my BIOS since Intel Desktop Utilities didn't work before. Once I did so, the system restarted and starting posting memory problems. Before the update, I had four sticks of 8 GB installed, with no problems at all. However, now I can only use two sticks of RAM (16 GB total) at one time. I tested each stick, and each runs fine individually. What is the problem?
Also, a side question: when I updated the BIOS, my computer boots to an Intel Desktop Board inside logo, but no longer shows the sleek Windows 8 logo. How do I get it back? Thanks!
DArce
Valued Contributor III
Did you try a BIOS roll back to the previous version to see if the issue mentioned above are BIOS related?
What is the part number and manufacturer of the memory sticks that you are using?
HYu18
All four sticks are Corsair Vengeance 8GB) DDR3 1600 MHz (PC3 12800) Desktop Memory (CMZ16GX3M2A1600C10).
I've been hesitant to make any more changes to the BIOS. Is it safe to rollback after updating? How far should I rollback to?
DArce
You should just try to roll back to the version that you were using before as it was working fine in your system. it is safe to do that roll back.
If you do not know what version was installed, try using the previous version on the web site. For this, use the BIOS recovery method as shown here:
http://www.intel.com/support/motherboards/desktop/sb/cs-023360.htm http://www.intel.com/support/motherboards/desktop/sb/cs-023360.htm
The file you need to use is posted here:
Download Center
