Intel® Desktop Boards
Peer-to-peer support only
11479 Discussions
DZ77BH-55K and Windows 7 SP1 only allows 764 GB of a USB mounted 3 TB disk to be allocated
LHame1
Intel motherboard DZ77BH-55k with an i7 processor and MS Window7 SP1. Adding the 3 TB for backup use. Selected GUID partition style, but still can only 764 GB of unallocated space. Used the Intel driver update utility to no avail. HELP
IUman
Hello SDLarry,
Thank you for joining the Intel communities.
Please try to delete all your partitions and the volume for all of them and you will see them unallocated.
You can format them with Disk management tool.
If the Disk only shows 750 GB on the left you may need to convert it by right clicking on the disk on the left side and select convert to GPT.
The Master Boot cannot detect a 3TB disk.
See if the video at the following link can help you.
https://www.youtube.com/watch?v=NHAIDprjmYo https://www.youtube.com/watch?v=NHAIDprjmYo
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Ivan
