Intel® Desktop Boards
Peer-to-peer support only
11432 Discussions
DZ77BH-55K post code 36
DFitz5
I have a DZ77BH-55K system that is showing post code 36, but don't know what to do next with it.
Originally, the error was in a frozen state - no response. Went to reboot, but only 'sputtered' (the best way
to put it). Replaced the power supply - came up with post code 32 and the three beep audio sequence associated
with memory error.
Updated to bios 0100 because appeared to be similar problem to an existing thread. No success. Went to
removing dimms, and got it down to one 8Gb stick in the # 1 slot that got it past the three beep audio sequence,
but stuck on post code 36.
Any help/pointers appreciated.
--Dan
AScot
New Contributor II
I am not familiar with this board... But would recommend clearing CMOS by removing the battery and waiting 30 minutes, then replacing it. That may fix the problem if it is corrupted CMOS memory (which can easily happen with a bad power supply).
