Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
DZ77BH-55K right angle SATA ports.
This board has right angle connectors for SATA. I've never seen that before.
These connectors are at the front edge. In my computer cases, there is 7/8 inch clearance between them and the hard drive rack. It is hard to plug in the cables. Probably even harder to unplug them.
This doesn't make any sense to me. Am I missing something?
Steve
Highlighted
The DZ77GA-70K has a similar setup. I ended up putting the cables on before I mounted the board because I didn't have enough room to work with the board screwed down.
