Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
DZ77GA-70K BIOS mouse issues
I have a Razer Imperator 2012 and getting this mouse to work with the BIOS seems to be downright impossible. If it wasn't for the classic mode I probably would have gone made by now. Anybody have any similar issues with mice on this board?
Tags (1)
Highlighted
Community Manager
To answer your inquiry we don't have any reports of issues with this particular mouse(Razer Imperator 2012).
Here are our recommendations:
1. Make sure to have the latest drivers or updates for the device.
2. Test with a different one in order to narrow the issue properly.
Highlighted
Community Manager
Hi Dan, thanks for the info, it seems a full reset of the BIOS fixed the issue and I haven't had any issues since. I guess a setting got jammed somewhere and broke the mouse capability in the BIOS.
Highlighted
Community Manager
You solved your problem but if anyone will have similar issue in the future this is probably the cause:
If you turn on "Fast Boot" USB optimization the mouse will not work in bios. I noticed this today when i enabled all 3 fast boot options and then i went back into bios but mouse did not work. Then i remembered that USB optimization was on. Had to reset bios to be able to use mouse again.
Highlighted
I am having the same issue with my mouse while working in the bios it randomly moves around the screen and trying to click on anything is almost impossible. i am running a microsoft mouse and keyboard, keyboard works fine but the mouse clicks on stuff all by itself. i have not fast booted anything as well it cant be done using the mouse lol. will try a wired one when i get home
Highlighted
Hello battlestar,
This is an old thread now so please open a new thread and provide full detail description so we can continue there.
Kevin M
