With the current BIOS, if I change minimum fan speed percentage for the AUX, Inlet and or Outlet fan, the computer will not boot.
I have to use the back to BIOS button to reset the BIOS.
One time on a reboot (installing WIN8 updates) all drives (hard and optical) disappeared. BIOS showed no drives hook to any SATA port. Shutting the computer off for about one minute, the drives reappeared.
The following information is from Intel(R) Desktop Utilities:
Board:
Manufacturer Intel Corporation
Product Name DZ77GA-70K
Version AAG39009-401
Serial Number BQGA23700055
BIOS Version GAZ7711H.86A.0066.2013.0521.1509
BIOS ROM Size 8256 KB
BIOS Release Date 5/21/2013
Processor:
Manufacturer Intel(R) Corporation
Processor Name Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
Processor Speed 3.5 GHz
Stepping 9
Form Factor Socket LGA1155
Hyper-Threading Technology Status Enabled
Memory:
G.Skill F3-1600C9D-16XM
Socket Designation DIMM1
Current Memory Type DDR3
Installed Size 8192 MB
Memory Speed 1600 MHz
Socket Designation DIMM2
Onboard Devices:
Device Type Video
Device Description Intel(R) HD Graphics Device
Device Status Disabled
Device Type Ethernet
Device Description Intel(R) 82579V Gigabit Network Device
Device Status Enabled
Device Description Intel(R) 82574L Gigabit Network Device
Device Type Sound
Device Description Intel High Definition Audio Device
Hard Drive/Optical:
SATA 0
Model WDC WD10EZEX-22RKKA0
Size 931 GB
SATA 1
Size 931 GB
SATA 3
Model INTEL SSDSC2CW240A3
Size 223 GB
SATA 2
Model LG BH16NS40
SATA B
Size 931 GB
Video card model number:
Model Sapphire HD 7870 GHz Edition
Power Supply:
Model Seasonic Platinum 860
Wattage 860
With the current BIOS, if I change minimum fan speed percentage for the AUX, Inlet and or Outlet fan, the computer will not boot (should be POST).
Fixed, was related to unchecking Legacy Boot.
On some reboots, all devices connected to the Intel SATA chipset (hard drives and optical) disappear. No connected devices appear in BIOS.
Has happen twice today.
Have to power down and turn power supply off.
Secondary SATA drive, does appear in BIOS.
Don't believe it is power related, as the all the hard drives (primary and secondary) are getting the power from same source.
The optical drive shares power with the CPU water pump and RDX drive.
Submariner, is this only happening with latest BIOS? Is it possible to test with an older version?
Just to make sure that is not power related you may try stressing the system somehow and verify the voltages with Intel® Desktop Utilities at the same moment.
Intel authorized an RMA today.
Today, I did have the Intel® Desktop Utilities (no problems noted) running on the desktop, while chatting with the Intel rep, I restarted the computer.
After post, it reported no bootable devices, in BIOS it showed no devices attach to the primary (Intel) SATA controller.
