Intel® Desktop Boards
Peer-to-peer support only
11475 Discussions
DZ77GA-70K Can't recognize LSI 8708EM2
JLi92
My DZ77GA-70K can't recognize the LSI 8708EM2 raid card.
It even didn't show on any PCIE slots inside bios.......
Pls help, is there any i have to config to find the card......
HSore
I do have kind of same error as well. DZ77GA-70K board, trying to get an ARVOO, Leonardo card working.
The computer does only regonize the PCI card, in 1 of the 2 PCI slots?
Silvia_L_Intel1
Unfortunately we do not validate the compatibility with RAID controllers on our Desktop Boards. These are usually for server systems.
However, you can try the following in order to check if the PCI-e is or not defective.
1. Test another device on the PCI-e and check on BIOS if it is being recognized.
2. On BIOS, go to the "Boot" tab and under "Boot display options", check if the setting named "Expansion card text" is enable.
3. Check for a BIOS updated if needed.
4. Test the system out of the chassis.
JLi92
Have tried all the above and still can't recognize the PCI-e card......
it seems the problem of bios or UEFI issue.......
Really hope Intel can look into this problem and provide new bios update.....
ZAgha
New Contributor II
That card is a bit old. Have you tried updating the firmware on the card.
Another thing try not to use it in UEFI mode.
