Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
DZ77GA-70K Intel's USB 3.0 Front Panel Hub Cable Too SHort
EOjed
Hi !!!
Just a quick remark about the USB 3.0 front panel hub, cable is too short on a CoolerMaster Cosmos 1000 Case.
Do you know if Intel has another USB 3.0 Hub for this MB with a LONGER cable?
If there a "compatible" HUB out there in the market that could have a longer cable?
E1375
DArce
Valued Contributor III
That is the only type of bracket that is being offered for Intel(R) Desktop Boards. You may need to check directly with the bracket manufacturer for testing or compatibility information.
For a list of tested hardware for this motherboard, you can refer to:
http://www.intel.com/support/motherboards/desktop/dz77ga-70k/sb/cs-033467.htm Intel� Desktop Board DZ77GA-70K — Tested peripherals
EOjed
Perhaps, what I will do is carefully cut the cable in the middle and weld an extension. It should not be difficult. I'll let you know if it worked.
e1375
