Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
DZ77GA-70K bios version 0049
I wonder if you could help me try to boot my DZ77GA-70K motherboard into linux. I was able to boot in uefi mode from cd/usb with version 0035 of the bios. However I could not get booting from the hd to work.
With version 0049 of the bios, I am not not even able to boot into uefi through a usb/cd. It gets stuck after it attempts to load vmlinuz.efi
Are there any known bugs with version 0049 that would prevent me doing this?
Highlighted
Community Manager
Hello yuumei,
I understand that you are experiencing problems with UEFI boot using Linux*.
I recommend you to post your inquire in to the Linux* forums, they may have additional experience on this matter as Intel(R) is not validating Linux* based operating systems as compatible.
Regards.
PV
Highlighted
Community Manager
Ah ok, helpful. Could you at least tell me what the status code "C6" means? It is not on the sheet of status codes.
