Intel® Desktop Boards
Peer-to-peer support only
11428 Discussions
DZ77GA-70K board wont turn on, 3 beep error code 20
apale2
Hi All,
I have a problem...Ive had this board for a couple years now and its worked perfectly on the lastest bios. Recently I installed a 3 pin fan to the rear and aux fan header on the motherboard and the cpu wont turn on and its giving me the 3 beep and error code 20. I took out the 2 fans from the header and everything is back to normal. I looked in the bios and the fans are set to Auto for both headers.
Can this board work with 3 pin fans? if so how? what do I have to change in the bios to get this to work?
apale2
The Problem was Speedfan...That program caused all this mess
