Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
DZ77GA-70K boot problems using card reader
Hello together,
I'm using the DZ77GA-70K board with an extern graphic card (my screen has no HDMI). In this case everything works fine, but when i also connect a cardreader (SATA) my board isn't able to boot anymore. Any ideas?
Community Manager
Hello anti1112,
The issue you are experiencing could be related to compatibility with the card reader (SATA) device you have. Our recommendation is making sure you have the latest firmware for the card and testing a different device on the SATA port to narrow the issue.
