Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
DZ77GA-70K bricked by BIOS update (thanks Intel)
The only thing that could make having to replace an Intel motherboard is when you try to update the old (Feb) BIOS of the replacement and the motherboard bricks and none of the recovery options work.
System won't boot with BIOS jumper removed--constantly reboots.
System won't find recovery BIOS on USB drive.
System won't find recovery BIOS on CD.
Apparently the recovery option is completely useless because when you really, truly need it, it doesn't work.
Anyone have any tips or hints? This motherboard has been a colossal headache. I've now lost multiple days of work on it.
Tags (1)
Community Manager
You are unlucky. I have updated 6-7 times so far and no such problems. If the jumper on the motherboard does not work then i don't know what you could try more.
Try: http://www.intel.com/cd/channel/reseller/apac/eng/support/429847.htm Live Chat Support
Community Manager
I've had success in the past with the following:
1. remove any device attached to any USB port (except keyboard, if you have a USB keyboard). For this particular BIOS, attach the keyboard to one of the USB 3 ports (blue insulator) on the back panel.
2. Disconnect the power supply from the mains (pull the plug)
3. Hold the case power switch (or the power switch on the motherboard) closed for at least 30 sec
4. reconnect the power
5. proceed with the documented BIOS recovery technique of your choice. BIOS 53 has an apparent problem with the USB 2.0 ports (black or yellow insulator) so if you're loading the .BIO file from a USB flash storage device your best chance of success will come with using one of the USB 3.0 ports on the back plane.
Community Manager
Thanks for the tips, unfortunately it did not work, the motherboard is dead as a doornail. Another replacement on the way.
I've also observed that the BIOS is flaky as hell dealing with USB keyboards and mice. It often completely ignores my pressing F2 unless I tap it repeatedly for about 30 times during POST. I would definitely trade the visual BIOS for reliable USB detection during POST. I've tried every port and had the best luck with the front USB ports on my case, which plug into the motherboard's first USB pinout. But only if the mouse is not chained off the keyboard, and only if I'm not trying to use the KVM, which the DZ77GA completely ignores no matter which port I plug it into.
And to top it all off I'm now terrified of updating the BIOS unless I have a spare motherboard handy.
