Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
DZ77GA 70K do not support gigabyte aivia osmium in bios
gigabyte aivia osmium can not be used in the 0049 latest bios, all key can not be used.
it can only be used after loaded into windows.
Community Manager
Hello hkmbe,
I understand that you are experiencing problems using the Aivia Osmium* Mechanical Gaming Keyboard to enter BIOS on the Intel(R) Desktop Board DZ77GA-70K.
In regards to the problem that you are experiencing with this keyboard, sometimes we can get there compatibility problems when some complex devices are connected to the motherboard.
I recommend you to o in BIOS and under the SATA configuration enter a hard drive delay, they will halt the system four a couple of seconds to allow the hard drives to initialize, but this will also allow the system to properly recognize your keyboard.
I will also report this issue as it was not reported to us before.
Regards.
PV
Community Manager
Hi ,
I think this is bios problem,because I have same problem in my motherboard (GIGABYTE X79 UD5 BIOS ver F9 & F12).
I contact to GIGABYTE . they give me a new test BIOS (F13e) this is OK. now I can confirm the BIOS with osmium.
so I think this is BIOS problem.
I hope this information can help you.
Regards.
