Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
DZ77GA-70K + g.skill sniper (3 beeps problem / dual channel problem)
Community Manager
Hey people, i bought an Intel mobo model DZ77GA-70K and i'm having this problem
I got 2x4gb 1866mhz G.SKILL SNIPER memory .. i can ONLY use the 2 sticks of this memory on slots 1 AND 2 (black and blue).. i'm having the 3 beeps issue when i try to use it on different slots or DUAL CHANNEL, i can only use 1 stick (4gb) or 2 sticks(but not in dual channel, instead, mono channel) ... any help will be very important.. maybe this is a mobo problem? maybe it's the memory incompatibility? maybe is the energy output? what do you guys think ?
I'm also using the i7 3770k with onboard video (intel graphics 4000)
thanks
TDalb
I was in the same issue with ram until place them on blue slots and load xmp profile from bios, not was able to manuaaly setting just go with xmp and they work well now.
