Intel® Desktop Boards
Peer-to-peer support only
11479 Discussions
DZ77GA-70K: new Bios on the way?
Community Manager
It seems that some of my problems with a DZ77GA-70K may be related to the Bios (currently using 0061). Since Intel already released many Bios versions for this board I'm wondering which of them is known to be the most reliable one? And furthermore: when will the next version be released? TIA!
Community Manager
I suffered from many issues and am happy with 0060; system is stable without issues. I won't upgrade unless I spot something in the release notes which I consider important.
Community Manager
Tried all different versions (including the latest 0063) and it seems that Intel can't make this board work as expected. Really sad, will go back to Asus.
Community Manager
Yes, there is still issues but this board is not so bad compared to others:
Community Manager
BIOS 0064 is on the board, available to download but I haven't been able to update my system from 0063 to the new version. Has anyone else tried to update to ver 0064? After the flash, I receive a message that it has completed successfully, but it's still on 0063. Anyone else try it yet?
Community Manager
I have 0064. Got a message that update failed but after trying again it was successful. Load defaults first.
Community Manager
Thank you, that worked! I set the BIOS to default settings, then put the 0064 BIOS version on a flash drive and installed it by selecting F7 when the BIOS screen came up. Version 0064 installed and I rebooted, applied my overclock settings and I'm all set. Thanks again!!
