Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
DZ77GA-70K - replacing motherboard with RAID
Jump to solution
I have a DZ77GA-70K which appears to have a bad integrated NIC. A replacement MB is on the way but I'm unclear how to handle replacing the motherboard with the OS on a RAID1 set. Will the new MB automatically recognize the existing array? Do I have to keep the ports the same? Or will I have to do a bare metal backup in Windows and restore that to freshly formatted RAID1 drives? Documentation gives no guidance at all.
Of course for safety's sake I'll do the backup anyway, just wondering what to expect/how much time is going to be involved.
Tags (1)
Community Manager
Yes, you can move to another board. Ports should not matter, just set the mode in BIOS to RAID.
(I had this some years ago, worked like a charm and it was a RAID 5 array)
PS: http://www.intel.com/support/chipsets/imsm/sb/cs-022435.htm Intel� Rapid Storage Technology (Intel� RST) — Moving a RAID volume to a different system
Message was edited by: Dominik
Community Manager
Community Manager
Thanks, you were right, the system saw the old RAID setup.
Unfortunately it then promptly bricked during a BIOS reboot.
