Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
DZ77GA-70K - unsuccessful POST attempt(s)
I have a new motherboard Intel DZ77GA-70K
Processor - Intel i7 3770 (not K)
OpticDrive - Sony
Memory - 4+4GB (16 GB Kingston)
SSD - Intel 510 (128 GB)
HDD - WD Black - 1TB
Power - Hyper 550W
I have 2 problem on my board
Problem 1: When I start or restart my system with Flash Drive Disk 16gb in USB 3.0 port I have error:
The system BIOS has detected unsuccessful POST attempt(s).
Possible causes included recent changes to BIOS Performance options or
recent hardware changes.
Press 'Y' to enter BIOS Setup or press 'N' to cancel and attempt to boot
with previous settings.
If I start my system without it - NO PROBLEM. I turn off boot from flash, but it didnt solve my problem
Problem 2: Aux and Rear Fans cooler dont work correctly in Auto mode. Some times start fans, some times no In monual mode work it work correctly, but speed changed only together. CPU and Front Coolers work in Auto perfectly. I use Noctua PWM Fans
PLEASE SORRY FOR MY BAD ENGLISH
Highlighted
Community Manager
1 View
1. I also noticed it is a bit of trouble to boot from USB 3.0. Whenever i plugin a USB 3.0 flash disk, it takes longer to POST. So what i do is: turn off PC, plug in flash disk, press F2 and boot it by selecting it in bios.
