Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
DZ77GA-70K with I7-3770K 3 independed displays???
I just bought DZ77GA-70K with I7-3770K with intel SSD and 32GB
IN the spec of the chipset and the processor it's says that it support 3 independed displays.
ALl i have on the mother board is HDMI connector
HOw do i connect 3 INDEPENDED (not duplicated) display (or at least 2 displays)????
Highlighted
Valued Contributor I
Hi
You are only able to connect the number of displays the motherboard manufacturer has given you. The DZ77GA is targeting over-clockers/games players who typically have little interest in the on board CPU graphics as they use one or more discrete graphics cards, for this reason this particular board only comes with one HDMI connector, so you can only connect one monitor running from the CPU/chipset.
Yes the CPU and chipset can support up to 3 displays, but that is only part of the story.
If you want more displays you would need to buy a separate graphics card.
The Intel media series boards such as the DZ77BH which target a slightly different customer, has an HDMI and DisplayPort connector and will support 2 displays from the CPU and chipset.
Motherboards from other manufacturers can be found with 3 graphics connectors to support the maximum number of displays from the CPU/chipset.
Phil
