Community
cancel
Showing results for
Search instead for
Did you mean:
IKhai
DZ77GA-70K won't show anything
I assembled my system which is:
DZ77GA-70K
i7 3770K
32 GB G-Skill (4X8 GB)
I hooked it to an HDMI screen and turned it on. Nothing was on the screen. The post code I get is 00, and the system beeps only once.
From what I read this means everything is ok.
What can be the problem? Why don't I see anything on screen?
Ilia.
Community Manager
try using something besides HDMI, even put a temp. video card in if you have one, just to boot. Then get into the BIOS and change the default video output to HDMI.
IKhai
Exactly what I did,
I connected an external card, got it working, got to the bios, selected the onboard as primary. Removed the external card, and no video again!
Any thoughts?
Community Manager
plug (external video card) in again, and in the bios set to use "onbaord if no primary" video card, and set the primary output to HDMI
IKhai
I did the first part, there's no option of selecting the HDMI as primary, I selected the intel ING as primary, but no good.
