Intel® Desktop Boards
Peer-to-peer support only
11477 Discussions
DZ77GA-70k not booting with Graphic card
EFahs
My Specs are as below:
  • Motherboard: DZ77GA-70K
    • Version: GAZ7710h.86a.3000.r09.1203090931
  • Graphic Card: EVGA GTX 760 FTW
When I tried to install my Graphic card I only sees a black screen, when I tried to boot the system without a graphic card it works fine.
Although I tested my graphic card on another machine and it also works fine.
Appreciate the help.
Silvia_L_Intel1
Hello Emad, thanks for joining the Motherboards community.
I would like to know if you have tried to update the BIOS on your board. I was looking for this BIOS version on our Download Center, but I was not able to find it.
This board has 15 BIOS versions; however I would like to get additional information from you before suggesting one specific version. https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3442 Intel® Download Center
Could you please attach the DX Ddiag report from your system so I can check the current information?
Dxdiag Report: Type dxdiag in Start Menu> open> Save> Attach using Advanced Editor Options.
This behavior could be cause by missing a fix or a new feature on the board.
EFahs
Dear Syliva,
Thanks for the reply
After checking this issue with Intel Support, they mentioned that this board I have is for (Engineer Testing) and was not meant for users.
Also that it's not recommended to update the bios.
I'm contacting the seller to return the item now, I bought it thru EBAY.
Thanks again.
Emad
Silvia_L_Intel1
Emad thanks for letting us know.
