Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11359 Discussions
DZ77GAL-70K with 3770K slow since day 1 on booting.
NCook1
I bought this board last year on Black Friday and I've been revisiting my hardware when I thought I should finally address this. After it posts initially (with fast boot on, tone off etc all the optimizations you can do without turning off USB support) it still takes between sometimes 5 (very rarely) to up to in extreme cases 80 seconds to get past it's screen where it just flashes the _. Now, other things I have noticed are little like sometimes pulling up the boot menu (escape) also shows incorrect devices (labels things as unknown volumes, generic USB device etc) but sometimes labels them PNY (model no here) Intel SSD (model no here) etc. I know it's a bit late in the board lifetime but there's some clear and obvious bios changes that could be made to fix issues like this.. I bought this board ON SALE for $150. (down from $280!) and I was expecting the top of the line most awesome piece of equipment I could get only to find that my computer started dreadfully slowly... Any known fix/workaround to this?
Jose_H_Intel1
What is the BIOS version and operating system you are using?
What is the boot drive's brand and model? Are you booting from a RAID volume?Is it connected to the blue, gray, or black SATA ports?
Did you run any test on the boot drive?
Jose_H_Intel1
NCook1
It looks like the bios updates since the one I had installed (60) had at some point fixed this though I only see something similar to it in the patch notes about the blank screen and not booting at all. Thanks for your suggestion. My own mistake!
