Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
DZ77RE-75K / Adaptec 3085 won't boot with BIOS 049 and 045
BIOS version 039 works with DZ77RE-75K / Adaptec 3085. However, after updating to 045 or 049 the system won't boot to windows when drives are attached to the 3085 card.
I see in the release notes for 045 "Fixed issue with certain SAS card." I suspect this fix broke the Adaptec 3085. Anyone else able to fix/workaround this issue?
Highlighted
Community Manager
Hello Frank,
I understand that the latest BIOS versions for the Intel(R) Desktop Board DZ77RE-75K caused problems with the SAS controller card that you are using.
If the problem is related to the recognition of the card or hard drives on the controller there is an option called expansion card text in the boot tab in BIOS that may help with this issue. Also setting a hard drive predelay may help you with this. The option will be under SATA configuration in BIOS.
Regards.
PV
Highlighted
Community Manager
Didn't work for me. Also, enabling "expansion card text" disabled the status that you get when updating the BIOS. The only indication I had was the flashing power led.
I'll just stick with 039.
