Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11461 Discussions
DZ77RE-75K - Problems with shutdown
RGree9
I have been running the following system for about three months now. Over that time I have had a fairly consistent problem were after exiting out of Windows 8 and all way down to where the lights on the Monitors are flashing the system keeps running and does not fully shut down until I force it by holding in the power button for about 10 seconds. After then I turned back on the system and go back into Windows I do not get any error messages. I'm hoping that somebody can give me some insight into what might be the source of this anomaly and possibly how to troubleshoot and correct it? Any input would be greatly appreciated.
System Specs:
Intel Core i7-3770K Quad-Core Processor 3.5 GHz 8 MB Cache LGA 1155
Intel Desktop Motherboard LGA1155 DDR3 1600 ATX
Corsair Vengeance 16GB (2x8GB) DDR3 1600 MHz (PC3 12800) Desktop Memory (CMZ16GX3M2A1600C10
Themaltake Smart M850W Power Supply
Intel Solid State Drive 180GB 520 Series
Barracuda 2 TB 7200 Internal Hard Drive
EVGA GeForce GT 640 2048MB GDDR3 Dual DVI, mHDMI Graphics Cards 02G-P4-2643-KR
Antec Sonata IV - ATX Mid Tower Case
LG GH24 Internal CD Super Multi DVD Rewriter
Community Manager
Hello Ron.
The issue that you are experiencing could be related to any device connected to the motherboard. Currently I don't haven't noticed any issues like the one you are reporting. At this time I suggest you to test with the system as basic as you can, remove extra hard drives, optical drives, only leave one stick of memory and if possible test with different power supply and video card. Make sure that you are using the latest BIOS.
Regards.
Community Manager
Hello Ron.
Regards.
Community Manager
If you are running Windows 7/8 try disabling hibernation by opening an administrator level command window and typing:
powercfg /H off
Close the command window and reboot the machine.
Also, if running Windows 8 with a user account tied to online (cloud) services try creating a new user with a local only account and boot the machine into that user. From there, test the shutdown behavior and see if the delays persist.
Douglas_D_Intel1
Thank you rbmorse! I had the same issue as Ron, and turning off hibernation seems to have resolved my issue with shutdown, sleep and restart.
RGree9
I finally returned to Win7 and the issue disappeared.
RGree9
Hi. Thanks for the input. I have already switched to a local account a week ago and no change. However, I am wondering if you could shed some light on whether a something labeled as a critical error in event viewer is a potential contributor to this shutdown issue? Under "Summary of Administrative Events: there is an event type called Critical. When I expand it what is listed there is "Kernel-Power Event ID:41". If I expand that one it shows basically it as a recurring event on a daily basis. Any idea and suggestions? Thank you.
YSmir
I have the same problem. In my point of view the problem is in ethernet port. It causes freeze of all system and after forcing the system to shutdown with the power button, ethernet card still works and blinks with it's LEDs.
RGree9
As I noted, since going back to Win 7 64 I have not had one restart or power down issue. Since this issue surfaced with both my ASUS and Intel MB's and only when Win 8 was the OS, did the problem occur. To remain fair, I am not sure if the problem is specifically a WIn8, or a combination of the two MB's I elected to use? Regarding the ethernet aspect, I can't say if that was contributory or not for me. One unique issue I did run into is when I had my HP Officejet Pro 8600 hooked using a USB connection, my system was repeating the same shutdown problem and I happened to find it one day when it occurred by going and unplugging the cable. All of a sudden the computer completed a normal shutdown. I repeated this several times and it was definitely and issue for me.
