I'm building a new system soon and wanted to know if the following RAM was supported by this board as I'm having a little difficulty understanding some of the terminology on Intel's web site about what RAM is supported, here's what I'm looking at:
Kingston HyperX 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 Desktop Memory XMP Model KHX16C9K2/16X
Any help on this would be appreciated!
Hello Amtrak288, the RAM memory that you are inquiring about should work fine with the third generation processors and motherboards.
Usually you need to make sure that your memory is from a know brand, that is rated at 1.5v and that it meets the frequency supported by your processor. You can check this by looking a the processors specifications on the following web site:
http://ark.intel.com/ http://ark.intel.com/
