Intel® Desktop Boards
Peer-to-peer support only
11476 Discussions
DZ77RE-75K SATA Ports
Community Manager
I have this board installed in my desktop with the latest BIOS 0060. Everything appears to be working, but only 0 Port with the OS drive shows up in the BIOS. I am using an Intel 520 180GB SSD for the OS and Seagate Barracuda 500GB HDD for storage. Is there anything I should know about setting up my HDD in Advanced > SATA settings?
thanks
ZAgha
New Contributor II
Are you sure that you have a non defective HD??
Can you connect a different HD?
Community Manager
I figured it out. There are 2 ports on the back of my hot swap trays, one is the primary and i had them plugged into the secondary.
thanks for the reply
