after sometime either when i sleep or out i come back the windows is restarted and not detecting my SSD, motherboard keeps telling me no bootable hard drive
restart wont solve it, i turn off my PC for 5 min then it detects my SSD
My PC specs
Motherboard: DZ77RE-75K Bios 0066
CPU: Intel Core i7-3770
RAM: 8GB x 2 Corsair CMZ12GX3M3A1600C9
VGA: Zotac Nvidia GeForce 580 GTX
HDD: Kingmax SSD 60GB, WD 1TB, WD 500GB, SeaGate 2TB
PSU: Gigabyte 750Watt
- Tags:
- SSD
Hello Hamood-d10, I am so sorry for any inconvenience this may have caused you.
- Please let me know if this issue started after the installation of BIOS v0066?
- Have you tried to use another SATA cable just in case this one is defective?
- Which SATA port are you using? If you install the SSD on another SATA port do you get the same behavior?
If the issue persisted, please get in touch with our Warranty Department so they can help you to replace the unit: http://www.intel.com/p/en_US/support/contactsuppo http://www.intel.com/p/en_US/support/contactsuppo
Once i boot the motherboard i updated the bios from the start, i didnt tried another sata port but i guess its an ssd problem because when i checked for bad sector using windows 7 it stuck at 29 for the whole day
i will try to do slow format for the ssd and install windows again and see if it fix the problem
Once you performed the troubleshooting, please let me know your findings.
the problem was the case was heating so i installed extra 3 fans and i cleaned my nvidia GTX 580 all is good to go
but recently i noticed problem in my LAN the secondary LAN keeps disconnecting and my PC become so slow i delete, install .... etc the driver many times same problem
this motherboard really sucks i really shoulda get asus
